1 - 4 of 4 Posts
Anyone know if the slightly longer Motorcraft FL-400s fits our cars? Both the Fiesta and Focus ST spec the FL-910s and i know the FL-400s will fit the Focus. Please let me know if anyone has fit it to the Fiesta. It is basically the exact same filter with a bit more length (and filter material).
thank you
it's kind of a tight squeeze in there even for a stock 910s... Not sure if the longer 400 would fit.. I've seen the motorcraft 910 cut open and it's a really high quality filter, I personally wouldn't worry about "upgrading".
It would be a very tight fit if it fit at all. I can't really see the purpose of the larger filter. Ford engineers know their business and selected the filter they did. As long as you change at good intervals you'll be fine.
400S will fit. Currently running an L20195 which is longer than the new 400S. I run it for the increase in surface area and the fact that I have a bajillion of them that I got on sale for a buck each.
1 - 4 of 4 Posts
