I was thinking about this when I was throwing my car around some corners. When I come out I usually get a ton of wheelspin with TSC completely off, the problem is stability control and traction control are tied together, so if you want to go sideways you also have to be gentle with the throttle on exit (which isn't always a bad thing). But I was wondering if it was possible to get a tune (maybe from COBB?) that allows you to defeat stability control but enable ONLY traction control, in either normal or sport mode.
