Damn, you run them that high? Same for DD use?2 events in. no issues. i'd be more concerned with them chunking than debeading. Run them at 37f/41r.
That's why you bleed them down before each subsequent run. And they never really warm up. At least, not in 60degree temps. In August, when tarmac temps hit 140 it might be a different story.Thats really high pressure, when those tires warm up youll be over 60psi, ya its a one lap race but i would stick closer to stock psi.
Oh, you mean you actually tested? Pfft, I'd believe the Internet before I'd believe real world testing!That's why you bleed them down before each subsequent run. And they never really warm up. At least, not in 60degree temps. In August, when tarmac temps hit 140 it might be a different story.
I've done some testing. Those are what pressures i've found the OEM tire likes to be at for the car to handle well.
Why would that be? Because consistency is a bad thing?Bleeding them down after each run is an even worse idea, but to each his own.
Start at 40, run and come off course, pressures will be about 45-46. While you wait, pressures will fall by a psi or so. Wait until a few minutes before you line up for your next run, and bleed back to 40. Rinse and repeat. Pressures will fall back down when the tires are cool again, but that won't happen during a normal run group.Say u start at 40 cold, u exit track at 45 hot. U bleed down to 40, tires cool now ur at 35. Now ur low on pressure, on track again and tires get hot u exit track and ur at 43 or so u bleed down again to 40 but ur really in low 30's cold. Do that a few times now ur starting cold in the 20's, ull be back in the 40's after a hot lap but ur in trouble cause tires and air is super hot, remember all the firestone ford blow outs in the 90's. All low tire pressure issues causings tires to over heat at speed. Id pick a presure and leave it for the day.
Camber is going to be the only thing that will even it out from what I've seen so far, and in GS, it's kinda limited as to what you can do. Tire pressure is going to help with roll-over on the shoulder, but a good alignment and crash bolts (a kit i'm still trying to verify is GS legal for this car) are really going to be the only thing that will optimize the contact patch.Has anybody actually taken inside/middle/outside tire temps with their pressure settings? I'd be more interested in getting the best contact patch, I can make the car handle how I want it to with technique.
