1 - 5 of 5 Posts
Does anybody know where to find the reverse switch? The reverse lights no longer come on and when I put the car in Reverse and my front wipers are on, the rear wiper is supposed to come on automatically. It does not come on anymore in Reverse.
Does anybody have the torque rating of the reverse switch as well?
Thanks.
Discussion Starter · #5 ·
the switch is attached to the transmission right below the gear shifter. install went smoothly but some tips for install:
  • airbox has to be removed, and removing the evap tube would've made life easier
  • clean the area before you remove the switch. I wish i did, now i'm worried about all that gunk that fell in
  • i was able to get an adjustable wrench on it, but just barely. its only needed to break it loose. can be turned the rest of the way by hand
  • it didn't have a socket that fit and it would've been nice to torque it to spec. i just turned until i could turn it no more
  • Motorcraft p/n: SW7033
1 - 5 of 5 Posts
