1 - 20 of 123 Posts
Boomba Racing Inc is proud to announce our new billet aluminum blow-off valve adaptor for the 2014+ Ford Fiesta ST
This high performance adapter mounts between the OEM bypass valve/solenoid and the stock turbo, causing the unused charge air to vent to atmosphere (VTA) giving off the well known, but distinct sound that all turbo owners know and love! The adapter bolts right in with the included longer bolts, no other modifications or tuning are required. Precision CNC machined out of high quality aircraft grade billet aluminum and available in 4 different colors
Installation is simple and all mounting hardware are included.
Only for use with the Ford Fiesta ST 1.6L Turbo engine.
MSRP: $65.00
Ford Fiesta ST BOV adapter
Solid looking Piece..
Reactions: Boomba Racing
Are the install bolts Grade 8? I had an issue with soft bolts snapping off inside the turbo when I added one of these to my MkV GTI.
Fun product, adds a lot of noise.
Do you guys have plans for a short shifter?
Yessir! Our engineers are looking into it!
Stronger than Grade 8 actually! The alloy steel socket head cap screws we supply have a minimum tensile strength of 170,000 psi and a minimum Rockwell hardness of C37, if that helps!
That sounds ridiculously loud. Looks well made though. Does it cause any issues for the ecu?
Absolutely zero issues! No CEL whatsoever!
That seems louder to my ears lol :)
It doesn't bypass the valve, just vents a small percentage of the air. If it bypassed it completely, the car would bog between shifts and throw a code for running rich
Nice! So no CEL? If not, i'm all for this! Little loud though. I'm not 18 with my first turbo Civic, ya know :)
EDIT; Keep making stuff like this!
Face White Hair Line art Nose
1 - 20 of 123 Posts
