1 - 2 of 2 Posts
Boosted Designs Solid Transmission Cable Bracket Bushings replace the stock Ford Fiesta ST rubber grommets that hold the transmission cable bracket in place.These solid aluminum bushings stabilize and eliminate excess movement and play from the transmission cable bracket when you shift. This simple and quick solution creates a more responsive shift by eliminating the sloppy feeling while increasing shift accuracy and improving your driving experience in your Fiesta ST.
  • Constructed from Aerospace grade Aluminum
  • Exclusively available in Boosted Design's signature purple color
  • Only basic tools required for install
  • Full color install instructions included
front_drivers_and_rear_bushings_1024x1024.jpg Trans_Bushings_f3e74af2-011a-45ce-92e1-fecf7a520692_1024x1024.jpg
1 - 2 of 2 Posts
