Just a FYI here is what Our Flywheel and pressure plate look like and the clutch disk is in there somewhere tooLearn something new every day.....
I had never heard of a dual mass flywheel. Looked it up and found this animation explaining the operation of one of these units:
Thought it was actually pretty cool.
This is EXACTLY what I get as well. To the t.I'm not sure if I am having the same issue, but to me it sounds a little more like a mechanical chatter than anything else. It is more noticeable within 2nd and 3rd gears and sounds like it is resonating from the center of the vehicle. It seems to be amplified when the car is warm or has been sitting in the sun while I'm at work.
That slight clunking noise when letting out the clutch shifting from first to second and sometimes second to third had me very worried as well! Glad to hear there is a normal mechanical operation that could explain it! I was worried I hurt something doing some clutch drops testing her out on the way home from the dealer before it was broken in enough or something!
Same with that apparent injector ticking noise which really got a lot louder at cold idle after I dumped the factory oil at 1000K!
Hey guys!This is EXACTLY what I get as well. To the t.
I've read around and its apparently normal, some linkage sounds or something.
And the sounds we're hearing is nothing like what the guys with clutch problems are having
Hi there,I recently had this problem diagnosed with my ford dealership who I purchased the car from. Car had 1,300kms on when I bought it. It had about 6,500kms when I began to hear a clunking only in 2nd, 3rd, and sometimes 4th.
The solution to the problem is a new transmission is needed. Hopefully you still have warranty! And be prepared to wait for a new one. I've been waiting for 3 months now!
Unfortunately, I'm unable to talk with customers outside of the platforms I'm on. There are a few different options, though. You can 1) send the info to me via PM here, but if you're uncomfortable with that there's the option of reaching out to Brittany directly on Facebook or Twitter.Hi!
Yes that would be great!! It seems almost impossible to get anything done in canada with this car!
If you'd like to email me directly and I can send you all the info you need.
My email is [email protected]
thanks
FacepalmThat slight clunking noise when letting out the clutch shifting from first to second and sometimes second to third had me very worried as well! Glad to hear there is a normal mechanical operation that could explain it! I was worried I hurt something doing some clutch drops testing her out on the way home from the dealer before it was broken in enough or something!
I fully agree with your theory. I'm also considering the RMM as a "fix" for this issue, among it's other benefits.And did the Cobb RMM fix this problem for any of you guys?
Has anyone made any progress on this issue. I have taken my car to the local Ford dealer and they could not replicate the problem. Mine seems to be happening when it is also more warm outside or the car has been running for a while. It is normally between 1,2 and sometimes 3rd gear. It is a clunking noise found sometimes even when stopped but most often when driving at slow speeds. My theory is that the engine is shifting maybe because of the weak motor mount and when it does the clutch or drive system is either elongated or shortened and is not operating at optimal length causing some kind of clunking noise. If it is related to a rubber mount or something then when the plastic or rubber is heated up it would be more pliable and flexible causing more shift and causing more misalignment. This is just a theory I have but it all seems to fit in place. All I know is something is definately up and I need this resolved quick as I am running up on 17k miles on my 2014 already. Any ideas anyone? And did the Cobb RMM fix this problem for any of you guys?
Hey guys,Cctman, it sounds like I have the same clunking as you. However, I also experience it while accelerating and decelerating. Is this true for you as well?
I thought the same thing, but nope, identical before and after the RMM. I've filed it under a quirk and am letting things play out for a while. I also have what sounds like an input shaft bearing beginning to go...still pretty faint so I'm going to sit on it for a while, but makes me think they both may be related to some tolerance issues.And did the Cobb RMM fix this problem for any of you guys?
If you have a 2016 there's a tsb. I'm getting the dealer to look at mine since it's a defect in the axles.
Clunk Noise Shifting From 1st To 2nd Gear ? 2016 Ford Fiesta | ford.oemdtc.com
Sent from my Nexus 6P using Tapatalk
