1 - 7 of 7 Posts
Does amsoil make a 910s filter? Also the 910s also has a anti drain back valve.
Premium Member
Discussion Starter · #5 · (Edited)
Yes there is a standard fitment as well. The standard size is only warranted for 15k miles versus 25k on the larger due to the small capacity, if you're into extended intervals. If you're going for OEM intervals that doesn't come into play.
Personally I just go for more oil capacity if I can get it. Fiesta is the first car I've owned that takes less than 6 quarts..
There were some people asking in another forum if the larger filter size worked, Mountune indicated it would so I thought I'd give it a try.
Sent from my SCH-I545 using Tapatalk
Thanks for the info. For me i just go buy the book about 10k an change the motorcraft filter about 3 times in the 10k.
1 - 7 of 7 Posts
