1 - 20 of 109 Posts
Premium Member
cp-e™ Ford Fiesta ST QKspl™ Downpipe
Introducing our cp-e™ Ford Fiesta ST QKspl™ Downpipe
Although more power and great sound are high priority items when buying a 3″ downpipe, the fine details are what ensure that the product will satisfy the end-user for a lifetime:
[h=2]FEATURES[/h]
  • More than 5% gains in upper RPMs
  • No power loss in lower RPMs
  • CNC-lathe V-Band turbo flange
  • Extra O2 bung for adding a wideband sensor
  • Laser cut stainless steel bracket
  • Industry-leading stainless steel flex joint
  • Stainless Steel honeycomb high flow cat
  • Mount to 2.50” or 3.00” exhaust flanges
  • Full 3.00” mandrel bent 304 stainless steel
  • 3/8” thick laser cut flanges
  • Included Smart O2 Simulator with Off-Road Downpipe
  • Made in the U.S.A.
  • LIFETIME Warranty
For more information please visit: Ford Fiesta ST QKspl? Downpipe | cp-e?
Soon
This downpipe looks VERY promising. I checked your website (which is pretty slick BTW) but didn't find any dyno runs.
Do you have any that you can post?
Any requirement to run stiffer engine/trans mounts due to the size of this downpipe (does it hit anything under heavy acceleration)?
Thanks
Premium Member
Discussion Starter · #7 ·
Thanks
Dyno graphs are up just click on HP or TQ pictured below
We also have not had any issues with it hitting on anything with the stock motor mounts. Hint: Those are coming soon too....
I'm a little confused by the TQ comparison table at the bottom of the Mustang Dyno chart. The graph makes sense, but the "blue" numbers for the stock setup don't seem to map to what the chart says. Same applies to the 3-inch exhaust chart. HP numbers look right as far as I can tell. The stock TQ numbers look like they were dropped in from somewhere. Am I missing something?
288wtq stock? :)
Catback dyno shows the same 288wtq number.
I agree...something is really off with the torque dyno.
I might have to guinea pig for this and share the dyno charts of the results :cool:
Just a question. Do you have to have a tune with this? Will it throw a CEL? I was reading on the website that it won't throw a CEL but with my GTO I put headers and it had the 02 simulaters and it threw a light as soon as I started it.
Premium Member
Discussion Starter · #13 ·
We designed almost all of our products to work with stock parts. It will not throw a CEL, but a tune is recommended as with almost all power adding after market parts
Anybody know how easy or hard the downpipe is to uninstall and install? I installed my turboback on my old MK6 GTI, it was really simple and straightforward. I'm considering the catless downpipe, such a good bang for your buck for only $320, if I can install it myself in a couple hours I'll buy it asap
Reactions: GhostWhite
Premium Member
Discussion Starter · #18 ·
Have you found a DIY guide anywhere? I haven't
Our DP comes with step by step instructions with pictures
If you installed a turboback on your GTI then you should be able to install this one easy
From what I am hearing it is a 3 hr job with most of the time spent getting the parts out of the car. (finding just the right angle to extract the heat sheald and factory DP)
Yup exactly!
1 - 20 of 109 Posts
