1 - 20 of 32 Posts
Premium Member
cp-e has a long history with turbo charged direct injection motors and a passion for manufacturing extremely high quality products in their very own production facility in America. Their attention to design and quality is second to none. And now, they have released a few products for the Fiesta ST.
cp-e QKspl Downpipe w/ High Flow Cat Fiesta ST 2014+ - $465.53
cp-e QKspl Downpipe Catless Fiesta ST 2014+ - $305.19
The cp-e Qkspl DP boast a 5% gain through the entire rpm range. It fits with the stock turbo and includes a cnc milled turbo flange for easy installation. It is crafted from American Grade 304 Stainless. It is mandrel bent throughout to reduce turbulence in the exhaust flow and an extra O2 bung is included for those of you who would like to run an aftermarket wideband sensor and AFR gauge. An optional high flow catalytic converter is available that features a metallic monolithic honeycomb catalyst designed for maximum flow and surface area. If you choose not to go with the high flow cat, the off-road version features the cp-e Smart O2 Simulator to help eliminate the check engine light that would otherwise be triggered by the removal of the cat. The cp-e QKspl DP also features a laser cut gasket adapter to allow the installer to seamlessly fit the downpipe with the factory exhaust or a full 3" exhaust without impeding flow.
cp-e Nexus 3" Cat back Exhaust Fiesta ST 2014+
- $663.91
cp-e Nexus Twin Exhaust Tip Fiesta ST 2014+ - $188.10
The cp-e Nexus Cat back for the Fiesta ST is a full 3" mandrel bent exhaust system. It has a nice aggressive sound that maintains a very close to factory level note while cruising at highway speeds. This exhaust will give you the best of both worlds! Quiet when you need it to be and loud when you want it to be. Besides the awesome sound characteristics, the Nexus also features a ball and socket clamp system to allow more adjustability and interchangeability for the tip.
Quality and performance are things you can be sure of when purchasing a cp-e exhaust!
Premium Member
Discussion Starter · #10 ·
Just checked out the new finish on the downpipe. If its the same as what is on the exhaust tip (and I'm pretty sure it is), I think it will look great!
1 - 20 of 32 Posts
