I am swapping a US Spec. 2014 Fiesta ST power pack (engine + trans) into a kit car chassis. I am trying to use the stock wiring harnesses and engine management systems. I put the Fiesta fuel pump into my fuel tank and have wired up the FPDM (Fuel Pump Driver Module) except for one wire. That is the wire to the RCM (Restrain Control Module) by which the RCM can tell the FPDM to turn off the fuel pump. From the FPDM that wire has 12v on it and I've read that it is a low current 12v signal.
As currently wired the FPDM is NOT send power to the Fuel Pump.
Anyone know what I can put on that wire to tell the FPDM AOK to run the fuel pump?
