That will be expensive to do. Wilwood makes a brake kit for the car already. [Fiesta - Kits] You don't want the Focus ST brakes. You want the hub. But I don't see that fitting.So i want focus st brakes and 5 lug hub in my fiesta is it possible? Mostly i want focus st rims om my fiesta can it be done?
That would be awesome! Thanks for being the guinea pig!I have taken the entire rear torsion beam out and inspected each component on the Fiesta ST. I am doing the same for the Focus ST next to see if anything is interchangeable. I'll keep you guys posted![]()
Excellent, look forward to it. My wife has a Focus, I'm sure see wouldn't notice a few swaps here and there.lolI have taken the entire rear torsion beam out and inspected each component on the Fiesta ST. I am doing the same for the Focus ST next to see if anything is interchangeable. I'll keep you guys posted![]()
If you could find a rear brake disk that fit the 4-100 and the Fiesta ST it would be a sweet swap.. well i guess you need a front disk too .. duhWhat would also be useful to know is if a Mazda2 hub can be swapped on so we can have access to a bolt pattern with better wheel selection (4x100).
Yes there in lies the rub.. they do make a conversion kit for the Fiesta back brakes though But yes they are Drum backsexcept aren't the Mazda2's rear drum?
AP makes a front kit: http://www.apracing.com/product_det...ta_st_mk7-front_4_piston_kit-cp6637-1004.aspx; available here: AP Racing Brakes | Big Brake Kits For Road & Track.Is willwood the only company who makes a kit for the FiSTS?
