1 - 11 of 11 Posts
Supporting Vendor
Ford Fiesta ST License Plate LEDs
License plate bulbs are used to illuminate the rear license plate on your Fiesta ST. From the factory, the bulbs are incandescent, lighting up in a yellowish color.
Newer luxury cars use LED modules to illuminate the license plate with modern, cool white light. By changing your license plate bulbs to LED, you can easily add this luxury look to your Fiesta ST!
The installation is 100% plug-and-play, just replace your factory bulb.
With low price and easy install, this is one of the best, easiest modifications you can do to improve how your Ford Fiesta ST looks at night.
Brightness:
Diode Dynamics offers several bulb model options so you can choose what output fits you best. These options are listed by the design and the lumen output of each bulb:
SMD2: Slightly higher brightness than OEM bulbs. (24 lumens)
HP3: Much brighter than OEM bulbs. These are bright! (56 lumens)
HP5: Nearly triple the brightness of stock OEM bulbs! (92 lumens)
Bulb Design
SMD2: Similarly compact design, with two 5050-size Epistar SMD chips, driven at high power for maximum effective brightness. Outputs at 180 degrees.
HP3: One high-power SMD under a diffusing lens for truly even output (no hotspots). Constant current design and air-cooled base for superior reliability. Features dual contact pins and nonpolar function for easy installation.
HP5: Four high-power SMDs, under a diffusing lens. Just like the HP3, but run at higher power, with integrated copper plating for superior heat dissipation, allowing maximum brightness.
These bulbs are made up of a quality plastic connector to slide right into the plug, as well as high durability terminals. A load resistor is embedded to prevent blowing the LEDs from voltage surge, and a diode is implanted to protect the LEDs from reverse polarity. The LED is wired for 12V operation, the kind found on all vehicles.
Included in your order is TWO BULBS (to fit your Fiesta ST).
All of our products come with a 30-day satisfaction guarantee and a 3-year limited warranty.
HP5 Cool White Installed (92 lumens):
If you have any questions, please don't hesitate to post, PM, or Email [email protected]
*PM us for the free-shipping code* (U.S. forum members only)
Thanks for looking!
Nick C.
Diode Dynamics
HP3 Cool White installed (56 lumens)
Supporting Vendor
Discussion Starter · #9 ·
July 4th sale! 20% off all diode dynamics products!
Our biggest sale of the season starts NOW!
Save 20% on all products including License Plate Bulbs with coupon code: JULY4 now through Friday, July 5th at 11:59 CST!
Jake H.
Diode Dynamics
Click Here To Shop Now
Cannot be combined with additional discounts or free-shipping code
Supporting Vendor
Discussion Starter · #10 ·
/center]​
HURRY! Only a few hours left!
Save 20% on all LED upgrades with coupon code: JULY4 at checkout! Head over to our website before this sale is gone! Sale ends Friday, July 5th at 11:59 CST!
Jake H.
Diode Dynamics
Supporting Vendor
Discussion Starter · #11 ·
Diode Dynamics’ Memorial Day Sale is going on NOW through Friday, 6/3.
Get 15% off all LED lighting upgrades with code "USA22" during checkout!
Plus, all orders over $300, will receive FREE shipping.
Click HERE to shop Diode Dynamics LED Lighting products!
Note: Products on pre-order (Elite Series Fog Lamps) are excluded from this sale.
1 - 11 of 11 Posts
