1 - 20 of 45 Posts
GarageLine.com: Fiesta ST Accelerator Pedal Mount Kit
Fits 2013-2017 Fiesta ST
Introductory Sale: $85
Info:
The GarageLine Fiesta ST Accelerator Pedal Mount FiST-APM Patent Pending is the first to offer a one piece design to adjust pedal height and lateral placement. The APM moves the pedal up from the stock position making the accelerator pedal closer to the height of the brake and laterally closer to the brake pedal for ease of blips of the accelerator or even heel toe braking if you are inclined.
Designed to be a functional modification for everyday use much like an short shifter assembly. The APM is designed in house using our CAD modeling software and tested on real cars to ensure the results of a great final product. These are built on our in house HAAS VF3 we use 6061 billet aluminum to make these sturdy pedal mounts.
30mm height
Installation is easy can be done with basic tools. Install time should take no longer than 15 minutes. All hardware required will be included in the kit to make installation a breeze.
https://garageline.com/2013-fiesta-st/101-garageline-2013-fiesta-st-accellerator-pedal-mount.html
[email protected]
240-516-8863
Oh my god! Excellent! This has been my problem with the car since day 1! My order will come in shortly!
then don't get it. I wear boots a lot, therefore, my feet are wide, this will not do.
Well, I went to install mine today. None of the bolt holes lined up. They where about 2-4mm off. Both with the OEM pedal assembly and the base to the floor studs.
Couldn't install it.
Build date of 11/13.
Already have an email to Garageline.
1 - 20 of 45 Posts
