41 - 50 of 50 Posts
Spacers are back in stock!
If you plan to use the 15mm in the rear you will need to trim the stock wheel studs. The factory studs are longer than the thickness of the wheel spacers. Which is why you will need to trim them. Alternative solution is to use 15mm in the front and 20mm in the rear.
is this for OEM wheels only or would this affect the aftermarket ones as well?
41 - 50 of 50 Posts
