So I installed the GT Yellow headlight armor today. Let me just say this first, these headlights are a very odd shape. You don't really notice until you have to affix something to them. It took me a good 45 min per light. Additionally the towels that they gave me with my order that are a must have left lint all over when using them, so I switched to a MF towel that I had. This isn't that bad until you get to the edges and it plants lint under the edge. when doing first alignment which is almost impossible to get off. You also aren't supposed to touch the material much. I have a lot of haze which headlight armor says will clear up in a few days. I'm sure that's true. I am surprised how hard it was to get this aligned and fit to the headlights though. It is not an easy process, and you need patience. The hair dryer is a must. I watched the Focus ST video, which actually hurt me more than helped. The Fiesta lights don't have the same curve to them. So you need to align and work them a little differently. I highly recommend aligning to the front and then starting from the headlight bubble and go outward. if you go forward in like the video, you are going to run into alignment/bend/rework issues, unless you just happen to get it perfect. The thing is, because of the curvature it's very hard to line up on top and bottom about 2/3rd down the headlight. Other than all that it wasn't too bad. If you are used to working with tint/phone screen protectors/etc it will be a little easier.
Anyways here are the pics.
