I was intrigued by a friend's car which has a Kahtec flashing brake like mod ( Blinking Smart Stop - Flashing Brake Light ) that I had to get one. I popped open the 3rd brake light and there's plenty of room to mount the small unit but you have to splice into the wires. Only slightly unnerving given it's a new car and under warranty but shouldn't be too bad. My inquries are as follows...
Splicing...
1) Should I splice right behind the 3rd brake light plug
or
2) Should I splice into the wiring inside of the car behind the driver's side rear carpet panel?
Not Splicing...
1) Is there a place to purchase factory plugs so that I can create my own plug-in harness for this thing?
Sorry for resize quality, the connector below says: 968405-1A // material type: PBT-GF10 .
I would prefer the not-splicing option but if I have to splice I have to figure out where. There isn't much wire to work with on the 3rd brake light and the wiring bundle inside the car is fairly compact and bundled. Thoughts?
Splicing...
or
Not Splicing...
