Just got this amp in today, Arc audio XDI V2, 150x4 and 600x1 the way I will set it up, 7.5 lbs
XDi 1200.6 | Arc Audio
I will mount the amp with the 10" sub and digital processor in a quick release spare tire well setup to take it out for track events but the total weight will be only around 22lbs when installed.
This is the first time I will ever run a D class amp, I have tried them over the years and never been satified but this is a just now released state of the art amp so I am going to give it a shot and am sure I will like it
The system will be stock NAV HU with an Audison Bit 10 processor that will automatically removed the factory EQing and restore the signal to how it should be but also is a 3 way crossover/EQ which will be able to have audiophile output to the amp.
Audison bit - bit Ten D
I would normally run the Arc Audio PS8 but it is a very very high end 8 channel processor and quite a bit to hook up and tune, it is just more than I need for this system.
Sub will be the Arc Audio 10 as I have used many, great sound and output for a reasonalbe amount of space required.
Subwoofers, ARC Series, ARC 10 | Arc Audio
I am using a set of older really low weight Arc mids, ACS 265 and Arc Black Line tweeters.
Tweeters, firing at each other mounted in the A pillars, 2" or so above the highest point in the dash.
Black 1.0 | Arc Audio
I would like to run these, they have huge output for a 5.25", more than enough for my needs and with a very well tuned sub crossover I do not need a 6.5" mid.
but I have the ACS 265 which are a 6.5 but not as robust though very low in weight and great sound quality.
Black 5.0 | Arc Audio
I do have a pair of the 4" Black Line mids and know of them being used in a 4 way front stage that worked very well, I might give them a try as barely heavier than the ACS 265.
Mount and enclosure will be out of fiberglass, Baltic birch plywood and Alumalite honeycomb so very solid and very low weight.
I will have the 8lb battery there as well, I have room for larger batteries if I end up needing one and have two sizes of Odyssey batteries here to chose from.
There will be a 2 qt window washer tank and pump as well, the tank and battery will be separate from the audio gear as it will stay in place for the track. (I might make the washer bottle mount to the audio rack as well, will see how it turns out.
Sound deadening will be done using some mat product, lots of acoustical/thermal foam and some aluminum channels to stiffen panels and allow less mat required, tie wraps, silicone sealer. It will be nicely deadened for very little added weight.
NO rear speakers needed or wanted, in the very high end audio competition world you seldom ever see rear speakers, the music is supposed to come from the front.
I have taken over 200 lbs out of the car and adding back around 50 to the rear where most of the weight came out from so it will help the balance a bit to add some back, it might work out I want or need to leave the system in the car at the track, I have raced with a system before.
The total added weight of the audio install with deadening will be around 30lbs.
If you take the time to do all the critical steps to reduce the weight of a vehicle, add just the right amount back, you can have a world class audio system for very little added weight.
You will not find systems like this installed in but a rare handful of shops as few in the business have ever even heard a championship caliber system let alone installed one, sad but true
This will be the 44th year since I installed my first car audio system, dozens since and I am still learning. I have been a competitor, judge, published but more important blessed to get to know and learn from some of the all time best installers, manufacturers, competitors.....
The most fun from this? Showing my fellow ST owners just what we can do for a very reasonable amount of weight, effort and cost, especially when I get to see you grinning like mad once you hear it
Have an excellent weekend!
Rick
Rick
