mountune Induction Upgrade Ford Fiesta ST 2014$299.00
You should be able to see detail in that one but for whatever reason, this forum software cuts pictures off.can you please take another pic zoomed out a little more?
Same pic in link form (can view the full image): http://oi42.tinypic.com/vhrvbl.jpgYou should be able to see detail in that one but for whatever reason, this forum software cuts pictures off.
Essentially, it's a replacement for the lower airbox and the filter with another source of air induction while still utilizing the factory snorkel.
I plan on it in the near future.May as well get the short shift kit too since you need to pull the air box to install that![]()
No. As this kit is more so a refined OEM style intake that utilizes the factory top portion of the intake box. Where as the Cobb unit eliminates the factory box altogether.would one be able to run both the COBB intake and this mountune inductionkit?
Not quite on the bolded. Cobb's actually uses the lower portion of the factory airbox.No. As this kit is more so a refined OEM style intake that utilizes the factory top portion of the intake box. Where as the Cobb unit eliminates the factory box altogether.
Thanks,
Jeff
