Being that I work at a dealership (not ford) I can tell you it will not void the warranty and it could only be an issue if it is the cause of some soft of transmission failure, but they would have to prove it.Would it not void my warranty?
Sent from my GT-N7100 using Tapatalk
Exactly to me the short shifter DID NOT change the way the car shifts it only changed the throw of the shifter which I found just a tad too long causing my elbow to find the edge of the armrest once or twice till I learned how to avoid that but didn't like that elbow in the air motion either... Best if you are on the edge about this is to find someone who has it installed and see if you can try it out for size though with how few of these cars are out there right now that might be a lil hard to do... All I can say is for Me it worksI think it shifts fine as well, I just think the throws are a little long.
So it did shorten the shifts then correct or are they still too long of a throw? Your wording makes it sound like it did and didn't at the same timeExactly to me the short shifter DID NOT change the way the car shifts it only changed the throw of the shifter which I found just a tad too long causing my elbow to find the edge of the armrest once or twice till I learned how to avoid that but didn't like that elbow in the air motion either... Best if you are on the edge about this is to find someone who has it installed and see if you can try it out for size though with how few of these cars are out there right now that might be a lil hard to do... All I can say is for Me it works![]()
