Santa brought me a Mountune quick shift and airbox. Since the airbox had to come out to install the shift kit, I figured to do both.
Mountune markets the shift kit as "easy to install". That is British for "small hands required". So, lessons learned the hard way for your consideration.
Be ready to unclip more connections than instruction pictures show. The OEM shift pin puller tool supplied is 15/16" because its a tough pull. It helps to use a rachet and socket on top so shift arm can be pushed back and forth to enable open end wrench to make a 1/16 turn on nut before turning it over and getting another 16th.
Do not drop the pin puller on top of the tranny, there is a place under the battery support you cannot see or find where the hex head fits perfectly and cannot be ticked out. Braille method from wheel well is only option move it back out to visibility if this mistake occurs.
Cut a slot in end of the hex screw that pins new assembly to shift arm before you start assembly so you can use a very thin slotted screwdriver from the top to pull the hex screw up through OEM shift arm past hand tighten point. Be ready for Braille key work anyway.
Curse Colin Chapman and all his small-handed cousins regularly, IMO he invented the concept of "possible is good enough".
It would take a magic elf to tighten the rear pinch screw, so get it about right before putting the new arm over the OEM arm.
Clean blood off nice new hoses before it dries.
Love the shifter now, seems much more natural. But 6th gear is just a bit shorter than 2 and 4, I may not have perfectly implemented my own advice on rear pinch screw.
Air box fits very well, but cold air supply routing per instructions is absurd. You either pinch the new hose beyond reason, or get under car and fabricate a harness to hold hose and open end where you want it. I did the latter.
