Only a 4 hr drive buddyIf you didnt live so far i would buy them.
Most likely TD Pro Race 1.2 or RPF-1 re-drilled to 4X108What wheels are you replacing these with?
Who's redrilling them? Id love to get a set of NT03's!!Most likely TD Pro Race 1.2 or RPF-1 re-drilled to 4X108![]()
There is a wheel works shop locally here in VA that does professional re-work of wheels, I need to have a talk with them to see the process, if its too much work, I will go with TDWho's redrilling them? Id love to get a set of NT03's!!
No they do notDo they have tire pressure sensors installed? Thanks.
Thanks. Let me ponder on this a bit.. I have three cars all of which take the same wheel/tire combo one of which wouldn't need the sensors and I may be interested in these. I'm also somewhat local which helps. I feel you on that dink in the one rim, I did the same thing on day 2 on a new set.No they do not![]()
Cool man, let me know if you are interested, I don't have any others currently interested and I can work with you on the price if you travel, thanks.Thanks. Let me ponder on this a bit.. I have three cars all of which take the same wheel/tire combo one of which wouldn't need the sensors and I may be interested in these. I'm also somewhat local which helps. I feel you on that dink in the one rim, I did the same thing on day 2 on a new set.
