1 - 3 of 3 Posts
Hi, I am planning on putting these in my Fiesta but I am not sure if they would fit, has anyone tried them. If you want to know obd2 scanner reviews, just visit AutoGuysLand to get more info. why do you think it says only Fiestas from 2011-2013? (mine is a 2017).
https://www.walmart.com/ip/Spec-D-Tuning-For-2011-2013-Ford-Fiesta-4Dr-Hatchback-Smoke-Rear-Brake-Tail-Lights-W-Led-Light-Bar-2011-2012-2013-Left-Right/197192380
:confused:
I think each model has particular specifications and features, so when you install something into, it should be fit, no error occurred. That will also make easily you install and your car will be nicer. You can find suitable thing in here.
https://www.carid.com/ford-fiesta-custom-tail-lights/
From a 2011 tail light, you will need to remove the center pin from the back of the unit. This pin in the middle isn't compatible with 2014+ fiestas. you will also need to repin the harness for USDM wiring. I recommend purchasing the tail lights from Whoosh motorsports. One of the few resellers who's active on the forums. and he provides pictures on his site on the necessary modifications!
1 - 3 of 3 Posts
