Hello,
Hopefully this post will help others save time, money and keep their hair from graying more rapidly.
I bought some winter tires and wheels from Tire Rack with the TPMS sensors already installed. I put the wheels on my car myself and thought it would be a simple task to set the sensors for the car. I struggled for more than week trying to get the sensors to be recognized by the car. There are bunch of different procedures for getting the car into "TMPS learn" mode. Tire Rack does not know the proper procedure for the Fiesta ST. I found one method that did get the car into learn mode but it still didn't work.
Today, I decided to give up for now and take it to NTB and have them do it for $5 a wheel. I took it there and they said the car was too new and they couldn't help me. So, I called a Ford dealer, they could help me next week if I scheduled an appointment and the cost would be $65. This was enough to encourage me to keep trying on my own. I will need to do this again in the spring when I put my summer tires and wheels back on. And this will be repeated twice a year, year after year.
I found a link to a video for the TMPS setup on a Ford Flex on thetpmsforum.com. This method was different from the other methods I had tried so I gave it shot. It worked and in less than 2 minutes I had all four sensors linked to the car!
If you have are swapping in four wheels and sensors, this the procedure.
Training new TMPS sensors for a Fiesta ST:
- You may need to drive the car for 20 or 30 minutes to get the TPMS fault light to come on before you start.
- Make sure the tires are inflated to the proper psi.
- With the car off, press and release the brake pedal.
- Press the ignition button and turn it on then off 3 times ending with it on.
- Press and release the brake pedal.
- Press the ignition button to turn it off.
- The horn should sound once and a message to train the left front tire should appear on the MyFord Touch screen.
- Use the TPMS-19 (TPMS-19-8C2Z-1A203-A) transmitter to train each wheel, starting the the left front and going clockwise around the car. You hold the transmitter against the sidewall, near the valve stem.
If you are doing a simple tire rotation, there is a another method below for getting the car into TMPS train mode which might work for rotations. For a 4 wheel swap, use the method above.
- Make sure your tires are inflated to the recommended psi.
- Push the start button without pressing the clutch.
- Push the hazard light (emergency flasher) button 6 times. The horn should honk and you should see "Train left front tire" on the MyFord Touch screen.
Drive safe.
Hiram
