1 - 4 of 4 Posts
I got some new TPMS sensors from here:
New Ford Lincoln TPMS Tire Pressure Sensor Set of 4 9L3T 1A180 BB | eBay
The sensors were installed into the old Contour wheels and tires mounted.
After driving for 30 or so miles, TPMS Fault came up on the MFT and in the dash. I tried to use the Ford Triggering tool with the hazard light procedure to train the tires, but the sensors do not react to anything..
Did I get the wrong sensors?
dumb question here but the sir pressure is correct ? and did you try bumping up the pressure a little bit to see if one of the sensors if just not Calibrated or something ? don't go over the pressure listed on the sidewall of the tire but it is shot in the dark.. Or sometimes they batteries fail in these things too if I recall...
1 - 4 of 4 Posts
