Cut ad pasted from a vendor website, probably cut and pasted from KW.
Two way adjustable, says infinitely variable on rebound, I would double check to make sure.
Product Description
KW Suspensions V3 Coilover Kit for all 2014-2015 Fiesta STs.
Outperform the competition on the track when you upgrade the suspension on your new 2014-2015 Fiesta ST with a V3 Coilover Kit from KW Suspensions!
V3 Coilover Features and Benefits:
- Corrosion Resistant inox-line Stainless Steel Spring Strut Casings
- High-Strength Springs
- Pre-Stressed Helper Springs Made of Flat Wire
- Polyamide Ring Nuts and Spring Plates
- Compression Buffer with Integrated Dust Protection System
- Damping Technology with Individually Adjustable Rebound and Compression Technology
- Perfect for Competition and Street Performance
- Individually Height Adjustable
- Adjustment Parameters Approved by the German Technical Control Board (TUV)
- High-Quality Components for Long Lasting Durability
- Infinitely Variable Rebound Damping Adjustment
- 14-Way Adjustable Compression Damping
- Unique, Individually Working Damping Force Adjustment
- Includes Detailed Instructions
Lowering Specifications:
- Front = 0.2" to 1.2"
- Rear = 0.2" to 1.0"
The V3, or Variant 3 coilover kit from KW Suspensions offers state-of-the-art technology from motorsports for increased performance on the road or the track. Designed with separate and independently adjustable rebound and compression damping, the V3 coilover allows for an individual suspension setup for many different driving scenarios and preferences. The innovative patented system with its two-stage valves allows a rebound damping adjustment (comfort) and a compression adjustment (driving dynamics) in the low-speed range while the high-speed range which controls driving safety, is fixed.
What makes KW Suspension coilovers the best on the market is the use of their exclusive inox-line stainless steel technology. Inox-line is highly corrosion resistant with unsurpassed quality and durability. After countless hours of use in all environments, the V3 coilovers will show zero signs of wear at the adjustment mechanism and should look perfect, just like the day you installed them. KW also designs each strut with trapezoid threads in the inox-line stainless steel to ease the ability of height adjustment when necessary.
If you're looking to upgrade your Fiesta ST's suspension, you want to get your parts from the leader in the suspension industry, and that's KW Suspensions. CJ Pony Parts now offers KW coilover suspension kits for the 2014-2015 Fiesta ST that offer state-of-the-art technology and several levels of performance, you can match the kit to suite your specific driving style.
Order a KW Suspensions V3 Coilover Kit for your 2014-2015 Fiesta ST from CJ Pony Parts today!
