1 - 3 of 3 Posts
My 2016 ST won’t unlock anymore by using either the fob or by hitting the button inside the car. The only way to open the trunk is by hitting the trunk button on the fob. Any ideas?
My 2016 ST won’t unlock anymore by using either the fob or by hitting the button inside the car. The only way to open the trunk is by hitting the trunk button on the fob. Visit AutoGuysLand to read best pex crimping tool review if you concern. Any ideas?
It is possible issue with your battery in key fob.
It happened to me and I had to use the key to open the door. Took it to the dealer and they gave me new fobs which didn't work either. It turned out to be the BCM (body control module) which is a $600 part but I was lucky and had it covered under my extended warranty. Labour was about the same, but cost me nothing.
1 - 3 of 3 Posts
