The COBB Tuning V3 Accessports for the 2014 Ford Fiesta are here! get yours now! We have them in stock and ready to ship! They ship fast! These also qualify for free shipping, PLUS our RallySport Direct 30 day money back guarantee!
Simple ECU flashing with gauge package! The new incabin mountable Accessport V3 has a large, full color, higher resolution screen which allows you to monitor up to six parameters in real time. Fully customizable from the look (multiple bezel colors), layout (set up race, street, or dyno gauge clusters), and mounting options (choose from 1,000s of standard vehicle mounts). And what's looks without brains? More processing power, memory, and storage to flash faster while saving all of your maps and logs. This is your new Accessport.
The AccessPORT is the most user friendly reprogramming device for your vehicle's computer. The provided mapping will optimize the air/fuel ratio and ignition timing, remove the speed limiter, and more for performance results you can instantly feel!
However, the AccessPORT is so much MORE than just a REFLASH DEVICE. It allows you to monitor your Fuel Economy (average and real time), perform performance tests in order to estimate your 0-60mph and 1/4 mile time, read and decipher ECU trouble codes (CELs), and monitor live data via the OEM vehicle sensors which eliminates the need for aftermarket gauges.
Giving you full control over the installation without removing your ECU ....the AccessPORT is truly more than just a programmer, it is the ultimate all-in-one solution for the Focus ST enthusiast!
Stage 1 Kit Includes:
- AccessPORT
- Quick Start User Guide
- USB Cable
- OBDII Connector
- Soft Case
- Blue and Silver Bezels
- Mount
Power Gains:
Stage 1 91*
Peak +3% HP / +12% TQ
Max. +5% HP / +15% TQ
Stage1 93
Peak +4% HP / +14% TQ
Max. +6% HP / +17% TQ
Results may vary. Power as tested on 2014 Fiesta ST vehicles using these identical calibrations.
Generally speaking, 91 octane calibrations have a richer fuel curve, and a less aggressive ignition advance map to help compensate for lower octane fuel blends such as those found in Arizona, California, and Nevada; and/or less than ideal atmospheric conditions. The maps designed for 93 octane are the most aggressive.
*91 and 93 octane results are compared against a 93 octane fuel baseline. Your 91 octane results may be higher than listed above; as a baseline of 91 octane fuel may read lower than our 93 octane baseline.
For more information, click any of the images below, or click HERE!
- AccessPORT
- USB Cable
- OBDII Connector
- Soft Case
- Mount
Power Gains:
Stage 1 91*
Stage1 93
