1 - 20 of 38 Posts
Hi guys,
I am planning to buy this car. But before doing that I need to know what are the common issues/ problems that you guys the owner know and/ or encounter.
Let me know please.
Thanks.
The only issues I have heard of would be some clutch issues with some 2013 builds and loose FMIC clamps on some early 2014 builds...I've also heard of a trany issue, but that was the only one I had ever seen....someone else may be able to chime in?
Cheers :)
Discussion Starter #5 (Edited)
Cheers :)
What is the issue? Is it covered by warranty? BTW, what is FMIC? Sorry.. ��
I've been following the transmission issue. It looks like some Fiestas had poorly machined parts inside of the transmission casing leading to premature noise and wear of the transmission requiring replacement (some owners have gone through multiple transmissions). I have also seen some owners complaining of premature clutch noise and wear due to cracked clutch plates.
Most seem to have been replaced under warranty. These are the biggest issues I've heard of, but not sure how common they are.
Some other common complaints I've noticed:
1. Creaks and rattles from the interior.
2. Loose side mirrors with noticeable vibration.
3. Thin paint (chips really easily).
Discussion Starter #7
Oh no!!! What country made are they? And what build year are they? Is our German made suffer the same thing as well? Is it covered by warranty here in Aust?
Pretty sure drive train components are made at the same place regardless of where the car is assembled.
The car has a dual-mass fly wheel which is a bit clunky noise wise... I'm not sure how many mistake this
noise for clutch problems. There are a few here with valid issues though.
I would add the Ford My Touch (stereo) is quirky as well, but not a deal breaker.
Remember these cars are hot rodded econo-boxes. The original Fiesta had a much softer suspension,
so (imho) some rattles are inevitable... Fortunately I'm not hearing any yet.
FMIC = Front Mount InterCooler.
Traction is an issue in first and 2nd gear when you get a tune. ??
Other than that, these cars are pretty great. And of course the very few issues mentioned above. I have a few little rattles in mine, but nothing big. Not to noticeable unless in listening for them. I have 4500 miles on mine. And every time I drive it, I get even more excited about it.
I don't know if it's common but I'll put it out there... the button on the hatch doesn't always work even with the key fob right next to it. I can always hit the button on the fob to unlock it, so I've never been locked out, but the rear hatch is supposed to work with the fob in proximity. Even if I've hit the button to unlock all the other doors, the button on the rear hatch doesn't always work. ...
Just sayin'......
From what I can tell most of the ones I have seen have been the Mexican built FiST's sold in North America. Not really sure what build years were affected. Any power train related manufacturing defect should be covered under the manufacturer's warranty.
Speaker cones tear easily in the German version.
Discussion Starter #14
How many of them are German build?
All 3 dr Firsta ST's are German made and all 5 dr's are from Mexico as far as I know
Although for how long who knows there is talk Asian production may switch to Thailand.
It will be under warranty so don't stress too much... Compared to the FoST the FiST is the good child. It's still a bit early to see what the issues are. Another 12 months and cars will start coming out of warranty then you will hear more.
Our car has had defective radiator, which led to engine replacement. We are now on our 3rd transmission. The rearview mirror on left side has been replaced twice and still vibrates to the point of being unusable. Tires wear very fast even under normal driving. The left windows rattle pretty good too. If I had it to do over would probably try a subaru wrx instead.
That really sucks, lemon law?
1 - 20 of 38 Posts
