21 - 31 of 31 Posts
Is the 2x6 really enough clearance to get at the drain plug and filter? I can't imagine being able to see what I'm doing with that much space...
I have two of 2x6 stacked together on one side and three 2x6 stacked together on the other side. With this setup, I think I only have enough head room (minimum) to change oil and tranny oil.
Another little tip. If you use a strap style filter wrench and find it slips when you try to remove the filter, tape a thin strip of 80 grit sand paper to the inside of the wrench where it will contact the filter. Just cut a strip the same width of the strap and use a couple thin strips of duct tape to hold it in place. The sand paper will bite into the filter when you put pressure on it and will not spin as will happen when you use this type of wrench and come up against a severally over tightened filter.
For the new filter don't over tighten. Tight is good, but you can tear the new filter gasket and cause a leak if you tighten too much. Generally I put on a grippy glove and hand tighten only. Never ever had a filter leak from hand tightning only. Looks on the FIST may be hard to do this where the filter is located, so may need a little tweaking with the wrench, but don't over due it or you will fight it on the next change.
I couldn't trust the boards to not slip... I ended up just jacking up the front drivers side, which was more than enough clearance.
Discussion starter · #25 ·
Yes it gives you enough room to get to the drain plug, and the filter... I'm 6'5" tall at 235 lbs, and I fit! There isn't any dancing room though.
This is why I stated in the How to: "your preferred way of lifting the front of the car up. I used an old 2x6 under the front right tire.
This was just enough room to get the job done for me. "
Happy Wrenchin'!
FWIW, there's a really handy built in holder for your emergency backup oil (I always like to have a spare quart with me, especially on long trips)
Excelent tutorial! Just changed the oil without any problems!
I still have to try to change the filter because it's " on it's way"
Andrei, Italy
lol, course I'd find this gem AFTER I do the oil change. days after.... great right up though. I had no idea what I was getting into, but I've done oil changes plenty, and everything was pretty much straightforward. even installed the mishi catch can
What about the oil that drips down from the filter removal, does it just burn off? Does anyone use anything specific to clean it off? I had a buddy that worked at an oil change place, they would spray it down with brake cleaner to get rid of the oil trails.
that oil drilling down from the filter in inevitable.., hate it. why is it so hard to design it so that the filter is on the bottom? anyway, just clean it. I used shop towels and clawed at the area until I was satisfied.
I've always thought it was a 13mm as well, will try the 1/2" out this weekend on my next oil change. Good write up.
Also, to add to the OP, make sure to add in a step to torque the oil drain plug to 21 lbs-ft or 14.5 Nm.
21 - 31 of 31 Posts
